Hey peeps we thought it would be a great opurtunity to have a cruise and BBQ up at Mt tambo on the 20th of May.
Will be meeting at Coomera BP at 9am and leaving at 10am. (Park near maccas) Depart 2pm to head down to finish off the day at the spit.
this will be a great time to meet new ppl and spend a day with mates. we would like a few cars to attend this so we can have a good day. Also if ya gonna eat bring some food and drinks. We are gonna supply some sausages and drinks, but it does really depend on how many peeps come. so a confirmed number would be good.
any more info PM me
and this will also be a multiple car site event.
So who's in?
Please note that this is not a mountain run, racing, burnouts, general bad behaviour will not be tolerated, We want this to be a great day without incident and to show everyone we aren't all hoons. Please leave bad behaviour at home!
Edited by hrn33_r33
https://www.sau.com.au/forums/topic/167190-sunday-may-20th-bbq-and-cruise/
hey
for everyone that is coming along can you please pm me to let me know exact numbers so as i need it in order to get the food and drinks for this event, so numbers will be needed otherwise we cant guareentee there will be enough for everyone to go around
thanks
CRUISE CANCELLED DUE TO MAJORITY OF PPL PULLING OUT LAST MINUTE
A smaller bbq/cruise will now be in place
meet at midday at coomera bp, will just be doing spit cruising, after heading to a bbq down the coast on the way there
any questions call 0400677777
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
