I can make a 3'' front pipe for you for about $150, they are a easy as to make and would be able to do it in about an hour if you brought the car to me at work, the dump pipe from the turbo is a lot harder to make and wont give much gains with stock turbo, a big cat is important also.
https://www.sau.com.au/forums/topic/1752-joel/#findComment-33223
Cool Bro that would be awsome! , Let me know when you can do it... can it be done on a weekend??
I am def keen to do that, $150 would be sweet as.
Whenever u can do it I will be in.
I live not far from andy at Fulham Gardens, and work in the city.
So dump pipe not worth it then? , I dont know what type of Cat I have. I dont know how to tell between high flow and normal.
https://www.sau.com.au/forums/topic/1752-joel/#findComment-33314
the dump pipe is may be worth doing but costs lots more, the front pipe gave me about 1psi gain in boost and felt alot better,I can do it on the weekend for you, the workshop is in burton witch is off port waikfield road about 10 mins before you get to air drag strip. The high flow cat is 3'' in size and is bigger about 300mm long a standard one would be alot smaller.
https://www.sau.com.au/forums/topic/1752-joel/#findComment-33825
Cool man this weekend?
I would def be up for that, I want to get both the front and dump pipe done at the same time so I dont have to worry about doing it at a later stage. I dont really mind how much extra it costs.
Let me know for either this saturday or sunday, any day is good for me.
Hmm def have to get a high flow cat I think if i dont have already
https://www.sau.com.au/forums/topic/1752-joel/#findComment-33829
I havent done a dump pipe for a internal wastegate turbo yet so as much as I know I could do it i would want to do it on my car first so I can figure out what to do as it is a bit tricky. If you find one I could fit it but they are about 300 alone, what other mods do you plan on doing as there would be little gains from it as it is not too restrictive.
https://www.sau.com.au/forums/topic/1752-joel/#findComment-33833
I can do it this weekend if you like mate, probably saturday would be best just have to get a few parts so let me know if you want to do it.
A high flow cat would get better results or none at all if you are game.
Yeah I could do a full exhast would have to work out a price though I mainly just do the pipe work so if you got a muffler I could fit the lot, may be worth looking for a second hand system from an importer it would be cheaper, i can only do it in mild steel as well stainless costs to much
My mobile number is 0418815974
https://www.sau.com.au/forums/topic/1752-joel/#findComment-34292
