hey all its time to sell my 32 as im trying to get money to buy another car thats currently for sale
i really need this sale quick as i dont know how long this other car will last
price is $13,000
'89 128***k's
5spd rwd
3" turbo back exhaust with de-cat pipe
tein height/damper adj coilovers
bigger adj castor rods with solid joints
newly fitted FMIC
boost T set @14psi
autometer boost gauge
greddy turbo timer
GTR front bar
pod filter
alpine stereo
head gasket done a week after i bought the car bout 3 months ago
new tyres front, near new on rear
jus past pits a 2 months ago
rego till nov
Pretty much had it off the road for 2 months now koz i lost my licence, done under hoon laws, so the cars maybe been driven for a month after havin the head done. Its still as is after it passed the pits, ride heights jus legal etc so your not gonna cop a sticker from the cops driving it home, paint is in good nik, nice glossy black, completly de-baged so its ready for sum dark tint to give that vip look, the interior is clean no tears in the seats or peeling dash just the vinyl around th door handle is starting to peel very small though
The previous owner also had the timing belt, water pump an viscous fan replaced so all the hard expensive works been done to keep the car running
i dont really want any time wasters or people telling me they have to wait for a loan to approve but dont mind hearing what you's have to say :)
koz i need the money soon
locality- perth WA
cheers guys
heres some pictures to convince you haha
Edited by G0TB00ST
https://www.sau.com.au/forums/topic/176662-sold/
price is $13,000
'89 128***k's
5spd rwd
newly fitted FMIC
boost T set @14psi
greddy turbo timer
GTR front bar
pod filter
alpine stereo
rego till nov
i dont really want any time wasters or people telling me they have to wait for a loan to approve but dont mind hearing what you's have to say :D
locality- perth WA
cheers guys
Alright mate no worries just message me sometime if your interested to check out my car my number is 0439986495 cheers wes
https://www.sau.com.au/forums/topic/176662-sold/#findComment-3263956
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
