Garrett GT 2510 Ball Bearing turbo
In South Australia, Adelaide.. but can post anywhere
Excellent Condition . no shaft play.will suit rb20det or sr20det i have the adaptor plate to switch from an sr manifold to T3 flange.. Has gaskets and lines included. the actuator is included just not shown on the turbo..never been on my car, but i brought it with my car!! i'm now goin a bigger turbo so do not require this one. this turbo is very very responsive being ball bearing.. capable of making around 240kw, with sum minor mods
ADDED...
Just found out that this will suit a ca18 too.. as it is a t25 flange.. but if u want it for a 32 i can giv u the adaptor plate too.. will work great on any of these combos.. R32 rb20det.. SR20det.. or CA18det.. very quick spooler, ball bearing turbo great condition.. can take upto 22-23 psi
Price Drop to $900 price now includes dump.. and downpipe :D
Ph- 0408 820 538
Cheers Chris[/size]
Edited by super_32
https://www.sau.com.au/forums/topic/178689-sold/
hey mate where you located? how many km's if you know? also do you know if the dump pipe design is same as std skyline?
Im located in South Australia, Adelaide
Sorry should have mentioned that its a 3inch dump pipe..the story i was told is that the turbo is from an sr thats why the adaptor plate is there to suit a rb manifold and i believe that the dump is a straight bolt to the turbo.. hope thats some help
Unsure of the Kms on turbo.. but had it checked over by Turbo Tune here in S.A.. checks out fine.. no shaft play
chris
https://www.sau.com.au/forums/topic/178689-sold/#findComment-3258903
thanks man.. there hasnt been too much interest.. so i hope this price does get it out of my garage ;)
Hopefully man, bargain at that price!
Good luck with selling it, people are missing out bad to pass it up at this price.
Unfortunately I have to pay for compliance before I can go spending 900 on a turbo!..
But if things change I will let you know.
Thanks,
Abu
https://www.sau.com.au/forums/topic/178689-sold/#findComment-3276855
  • 3 weeks later...
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
