Garrett GT 2510 Ball Bearing turbo
In South Australia, Adelaide.. but can post anywhere
Excellent Condition . no shaft play.will suit rb20det or sr20det i have the adaptor plate to switch from an sr manifold to T3 flange.. Has gaskets and lines included. the actuator is included just not shown on the turbo..never been on my car, but i brought it with my car!! i'm now goin a bigger turbo so do not require this one. this turbo is very very responsive being ball bearing.. capable of making around 240kw, with sum minor mods
ADDED...
Just found out that this will suit a ca18 too.. as it is a t25 flange.. but if u want it for a 32 i can giv u the adaptor plate too.. will work great on any of these combos.. R32 rb20det.. SR20det.. or CA18det.. very quick spooler, ball bearing turbo great condition.. can take upto 22-23 psi
Price Drop to $900 price now includes dump.. and downpipe :D
Ph- 0408 820 538
Cheers Chris[/size]
Edited by super_32
https://www.sau.com.au/forums/topic/178689-sold/
hey mate where you located? how many km's if you know? also do you know if the dump pipe design is same as std skyline?
Im located in South Australia, Adelaide
Sorry should have mentioned that its a 3inch dump pipe..the story i was told is that the turbo is from an sr thats why the adaptor plate is there to suit a rb manifold and i believe that the dump is a straight bolt to the turbo.. hope thats some help
Unsure of the Kms on turbo.. but had it checked over by Turbo Tune here in S.A.. checks out fine.. no shaft play
chris
https://www.sau.com.au/forums/topic/178689-sold/#findComment-3258903
thanks man.. there hasnt been too much interest.. so i hope this price does get it out of my garage ;)
Hopefully man, bargain at that price!
Good luck with selling it, people are missing out bad to pass it up at this price.
Unfortunately I have to pay for compliance before I can go spending 900 on a turbo!..
But if things change I will let you know.
Thanks,
Abu
https://www.sau.com.au/forums/topic/178689-sold/#findComment-3276855
  • 3 weeks later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
