hey i need help guys so see wot yous can come up with....
yesterday we had this gay ass flash flood thing and i had water literally splashing over my bonnet i know "***T!!!" and i finally got tha bugger home and tha next day i took it for a drive to see if things were ok andit bosted to about 0.1 bar and it jolted like it was running out of fuel and it kept doing it at all different levels of boost and revs but usually over 3500rpm
then i took it for a drive at night and it done tha same thing "once" then it was fine for about 10 minutes evun at 1.1 bar and it was runnin fine then it started again...
i have no boost cut or fuel cut and i have a z32 AFM "AFTER TURBO"
i was wondering coz i think a heap of water got into tha air filter "hks hiflow" and yer i dont know wot can you guys think of???
https://www.sau.com.au/forums/topic/18939-help-jolts/
