i have just got a profec b2 and i installed it onto my r33 gtst, now i am having problems as it doesnt want to stop boosting at all. I have checked the boost lines and none of them are kinked. i am not sure which way the filter for the boost line into the back of the unit is supposed to be? and also the wires running from the black booster that connects to the intake and actuator the wires for the clip on the back of the unit in the car were off and im not sure which way they are supposed to be? could someone please help?
https://www.sau.com.au/forums/topic/192533-profec-b2/
  • 1 month later...
Hey guys, jst a quick question....
I know in the instructions a clicking sound is normal while the solenoid vavle is operating but how loud is it meant to be? i can hear it quite easily from inside the cabin...
Cheers
https://www.sau.com.au/forums/topic/192533-profec-b2/#findComment-3566423
While on the topic - with that hose that comes out the back of the main unit... would that T off into one of the hoses off the back of the plenum? or would it be better to disconnect the stock boost gauge hose off the back of the plenum and connect that hose straight into the back of the plenum?
https://www.sau.com.au/forums/topic/192533-profec-b2/#findComment-3566518
Cheers
Make sure you rubber mount it, I just put piece of rubber of an old bike tube between the soleniod and bodywork.
https://www.sau.com.au/forums/topic/192533-profec-b2/#findComment-3566537
I just T'd it into one of the hoses coming of the plenum.
As for the clicking, it shouldn't be that loud. However this shouldn't mean it is faulty. You may just have a loud unit.
Dunno, i spsoe you could take it back and try another one?
https://www.sau.com.au/forums/topic/192533-profec-b2/#findComment-3566749
Im not overly concerned about it as its not affecting anything, just was wondering if they are all that loud. I do have it rubber mounted so that shouldnt be a problem. And it does say that a clicking noise is normal so im not going to stress bout it too much...
thanks for your replies tho!
cheers
https://www.sau.com.au/forums/topic/192533-profec-b2/#findComment-3566963
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
