hey guys
up for sale is a redtop sr20det out of a 93 model 180sx. its done ruffly 40-50 thousand kms since it had a stock rebuild and has never missed a beat since. the only reason why im selling is becuase ive been building a sr20 engine from scratch for hte past year and finnaly have finnished it. Recently my mechanic has fitted a set of HKS stage 1 cams with HKS rocker arm stoppers and a GREDDY sump, i was there when he fitted these parts and the head of the engine looked like it was new. no scoring no wear wat so ever and deffintaly no build up of gunk. Also when we upgraded the sump we also found it to be clean for wat we could see aswell. The engines ONLY a bare block with a stock sump stock cams.
since ive owned the car for the past 30thousand kms it has been serviced every 3-4000kms and has been well looked after. oil temp never reaches past 70degrees due to the big sump and water temp never goes over 75degrees due to low thermostate. its never overheated on me at all. For the buyer im willing to post up footage of the engine running revving cold start driving etc etc. and if ur local fell free to come test it out your self (any tests welcome)
For anyone who wants more info about the engine and condition im willing to hand out my mechanics number that has delt with this engine from scratch
The engine will be coming out proberly late next week and ready to sell.
1700
you may think that its abit exxy. But i know how much its worth.
located in qld. sunshine coast
thanks
https://www.sau.com.au/forums/topic/193060-redtop-sr20det-mint-condition/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
