Opened the bonnet today after a good hill climb, and there was a tapping noise above cylinders 1 and 6.
Now my car (R33 gts-t) is stock apart from full exhaust and pod. My fuel economy is about 450+ km to the tank, and the engine/gearbox seems nice and tight.
HOWEVER the turbo is on its way out (has been whistling up high for some time now and its getting worse). I only noticed the tapping develop recently. Perhaps the turbo is chewing up oil and not enough is circulating to the head? I dunno, oil pressure doesn't seem particularly low. And no oil is being spit out of the intake manifold or anything like that.
I hope its not bearings - but the noise doesn't get louder when the car gets hotter or revs higher. I've listened to other engines with bearings going and the noise they made was REALLY irritating and got worse.
Help?
https://www.sau.com.au/forums/topic/205612-tapping-on-1-and-6/
tapping is generally head, which is nothing to worry about, lifters with age just get louder and i doubt you'll notice any difference
a spun bearing on the other hand is more of a knocking noise, they are very different. If it sounds like its coming just from the head then its unlikely to be a bearing.
Its also quite common on these to get noisy injectors aswell. My bros car (has 180000km on it, but REAL kms) and his stock injectors tap.
How many kms has it done? I would check the oil first, and give it a oil/filter change aswell. If you dont really know what your looking at, it might be worth your while to take it to a performance shop and get them to give it a once over. Its always hard to diagnose something like knocks and tap noises over the net, it could be anything
The car has 110,000 ks on it. Its going in for a major service, then straight after that looking at a new turbo setup, PFC, injectors, pump etc etc.
It definitely is coming from the head, I put my ear next to each cylinder and listened. I'm not particularly worried because the car seems to run otherwise fine but the major service should pick up anything wrong with it either way.
Thanks alot for the reply mate =)
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
