hay everone, i want to get some work done to my r33 serries 2, is there in rb engine specailts in the gold coast or some where decent that has perofrmance parts in stock and a wide range, im after a decent boost controller, fuel pump and regualtor and some one to fit the above items,
any help much appriacted
cheers
andrew
ps, anyone but autobarn, or is there some one on here thats confident in doing this?
https://www.sau.com.au/forums/topic/205964-rb-specialist/
www.importworkshop.com has the manuals
If you go boost controller, get an electronic one. Mechanical ones are crap, boost generally falls off because they open up early.
Jaycar has great EBC's that are cheap and very nice to use. Otherwise any of the Traders in the For Sale section sell good bits
https://www.sau.com.au/forums/topic/205964-rb-specialist/#findComment-3648287
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
