I really need to know EXACTLY where the stock tuner is and EXACTLY how to get to it....
I have all the stereo cables needed, I just need to find where to plug it into the screen inputs.... there not on the back of the unit, there must be a TV/Satnav/etc tuner somewhere... Helps?
Check under the passenger seat.
How does your climate control work? S1 installed?
Climate control is above the DVD unit and is the same as the S1.
'Mode' selects where you want the flow. RH knob determines temp, but use A/C button for air con for any temp under 21 degrees. 'Auto' sets the climate control in auto mode (fan runs high) or use the 'fan' button to select fan speed manually.
If anyone here has a S2 Stagea, I have ALOT! of questions
Please identify yourselves so I can interrogate you one at a time ;)
and if you have fitted a DVD player to your stock screen, then contact me even moreso urgently :)
hey dude ask away :) i got a fold out screen but sure it cant b alot diff :S
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
