RB25DET S14 Silvia
Guest undergroundmspts
Hi,
I am from the United States and was wondering if the RB powered Silvia's are as popular as they are here? I am in the process of building a RB25DET 1998 240SX SE as our demo car, www.underground-motorsports.com. Do you guys know of anyone I could talk with in Australia to get further information on the right turbo upgrades, other basic info, etc?
Thanks for your time, I know that this information will be helpful to all U.S. citizens browsing this forum.
https://www.sau.com.au/forums/topic/21521-rb25det-s14-silvia/
if you check some of the US forums as well as sites such as www.meggala.com you will find plenty of info on RB upgrades.
we will be carrying RB parts soon, as they some are under development www.JDMpartsplus.com also, you will find that the flange on the RB25 matches HKS 2530, some Greddy/Trust turbos. and plenty of others.
its a T3 flange so the possiblities are endless.
as far as other upgrades go, Power FC or aftermarket tuned ECUs work well, the injectors are side feed and are more expensive to replace but necessary with turbo upgrades.
you will find that info is plentiful and that the swap is becoming very popular in the US as well.
if you need motors we have plenty of RB25 & RB26 motors being imported from Japan bimonthly.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
