1997 Nissan S14a 200sx Series 2
Body Colour Magenta, Interior black/grey
5 Speed Manual
150,000kms
Previous log books
Genuine reason for sale, Have two cars and getting married so one has to go
Engine and driveline in very good condition
Suspension in excellent condition
Paint in good condition, minor blemishes
Extensive list of modifications, there are no big power adders that take away smoothness and everyday drivability of the car.
All standard features work and are in tip top condition-
ABS
Power mirrors and power windows
Air Conditioning etc
Modifications:
Custom 3inch exhaust with twin 3inch tips
Xforce hi flow 3inch cat
Ceramic coated Turbo manifold
Hybrid Front mount intercooler
Alloy radiator
Spitfire ignition system including coil packs and ignition module
R34 GTR fuel pump
Extreme XHD Clutch kit
Bendex ultimate brake pads
Juran front strut brace
New ISC Coilovers – Height, Camber, Damper adjustable
Front castor adjustable bushes
HKS boost gauge
Sits on Work emotion CR KAI bronze 17X8 and 17X9 rims
Front tread 70%
Rear tread 50%
Front Fusion splits Rear 3way Pioneer 6” speakers
Tastefully modified with a healthy dyno power figure but not taken away from the engines life. It made 182rwkw on 11psi. Boost has not been past this amount except for dyno tuning. Recently been checked on the Nissan ECU diagnostic at TurboTune, no faults what so ever.
I bought the car completely stock from Smiths car dealership here in SA. Had a 3month warranty on it, therefore a RAA inspection was taken out and any problems fixed under warranty.
All of the modifications to the vehicle have been supervised by me.
Serviced every 5,000kms with Nissan genuine oil
Thousands of dollars worth of receipts
Interior is virtually immaculate
Never been Defected
Comes with all standard parts, Struts and springs, fuel pump, intercooler, coilpacks etc etc
Problems-
One of the rear quarter windows tint has peeled a small bit, very minor problem
ANY OTHER DEATAILS WANTED DON’T HESITATE TO ASK
PM ME FOR CONTACT DETAILS
Phone 0433070733
Email [email protected]
PRICE- $17,800 O.N.O
Pics-
https://www.sau.com.au/forums/topic/219034-fs-s14a-1997-magenta-in-colour/
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
