Nissan Skyline r33
1994 model
120*** kms
CASH OR SWAPS >> OR SWAP WITH CASH EITHER WAY!
ALL CARS CONSIDERED
EXTERIOR:
PURE WHITE
fresh respray about 1 year ago. absolutely immaculate. NO dents, scratches or anything at all.
PERFECT PAINT
GTR front bar, huge intercooler showing through, sideskirts, and rear pods.
standard rear wing
series 2 clear headlights and bonnet
19 inch DEEP DISH -- GOLD XHP rims with good tyres
with brand new chrome lock in nuts with tool and brand new key lock nuts and tool.
(each rim has 4 normail lock in nuts and one key lock in nut so that they can not be taken off unless you have the correct tool)
MIRROR TINT on windows.
new windscreen wipers
SUSPENSION:
CUSCO COILOVERS - fully adjustable
sits low
BRAND NEW SPARE TYRE AND JACK
ENGINE:
RB25DET
TURBO motor
HUGE HYBRID intercooler with polished chrome piping
turbosmart supersonic bowoff valve
3 1/2 inch exhaust from turbo back, including cat, going to a 4 inch canon exhaust.
120*** kms
lightweight racing radiator - keeps the engine super cool
just had new NIZMO heavy duty clutch
serviced every 5000 kms.
had major 100000kms service and has sticker to show.
just had radiator flush and new coolant, new belts, new oil filter and oil
New brake pads.
air conditioning flushed and regassed, changed dryer. stays COLD
just had brand new high beam and driving lights put in, xenon lights, new crytal side lights, and all interior and boot lights were changed to high quality bulbs. NEW indicator light bulbs and braking light bulbs.
Just had a new O2 sensor installed
Just had gearbox and diff oils changed
5 speed MANUAL gearbox
INTERIOR:
standard interior
JUST HAD BRAND NEW HANDBRAKE AND GEARSTICK LEATHERS PUT IN
PERFECT CONDITION. NO RIPS OR TEARS AT ALL.
genuine skyline mats
Genuine NIZMO shortshifter.
Nizmo gearknob
Nizmo chrome racing peddels
HAS JUST BEEN PROFESIONALLY CLEANED AND DETAILED
HAS JUST HAD A FULL SERVICE
has all the other standard things like:
power steering
power windows
power mirrors
air conditioning
EXTRAS:
Autometer PHANTOM boost gauge, installed as a pillar mount gauge
APEXI TURBO TIMER/ VOLTS/ CO2/ AIR FUEL MIX electric timer
STERIO:
sony head unit
1000 watt BOSS amp in boot
sony front speakers
sony rear parcel shelf speakers
registered in QLD
HAS ROAD WORTHY CERTIFICATE!!!
HAS NO ACCIDENT HISTORY
perfect condition.
LOCATED ON THE GOLD COAST -- QUEENSLAND
PRICE $15000 O.N.O
OPEN TO OFFERS OR SWAPS
post-48382-1213023524_thumb.jpgpost-48382-1213023534_thumb.jpgpost-48382-1213023544_thumb.jpg
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
