Hi guys, yep direct bolt on to the standard induction pipe... sounds similar to a pod but not as loud as the HKS pod I used to have on there
The Z32 looks to be the same size as the regular afm but I didn't measure it, I'll ask around to make sure
Yep I can post it no worries
Photo is about 6 months old, filter element is in good condition, I will take close up pics
https://www.sau.com.au/forums/topic/226114-arc-airbox/#findComment-3981775
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
