Got a damaged 33 gtst-t rolling shell with long motor and manual gearbox for sale.
The engine has 193k on it, last compression test showed all cylinders were between 143 and 145psi. Gearbox is fine, doesn't crunch or slip out of gear, has a nismo short shifter in it.
The damage is only to the front of the car, needs a new bonnet, front bar, headlights, radiator, engine fan and I think that might be it. Rest of the car is in pretty good nick, if you would like pictures of the car just leave your email address and I'll send them asap.
Any questions just PM me.
Cheers
Make:Nissan
Model:R33 gtst-t
Milage:193,xxx
Transmission:Manual
Colour:Silver
Complied?Yes
RWC supplied?
Currently registered?No
Price:$3000
Contact:
Comments / Modifications:Front end damage
Images:
Yeah I've got some pics, what's your email and I'll send them across.
Damage isn't that bad, will definitely need a new front bar, bonnet, headlights, fmic, radiator and engine fan. Front guards are unharmed.
Don't think I'll be wrecking the car.
Would've liked to transfer the RB and all the running gear into an s13 but funds do not permit unfortunately.
Any other questions, just let me know.
do you have pics how bad damage is and are you going to consider wreckign the car?
Hey mate where bouts in NSW are you located? could i have some pics? [email protected]. thanks
Hey champ, the car is located in Goulburn, I'm heading back to work now, I'll send you some pics when I get home.
Cheers
hey mate really interested in your car.
Can you email me some pics.
[email protected]
And if you can could you ring my office (02) 66527 766 and ask for Tony
Cheers
Sent the pics, and I left a message for Tony on that number at 12:35 to call me back.
Thanks
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
