Hey guys as the topic states i have a Power fc for a 33GTST, the hand controller is in good condition everything is working perfectly with it the ecu has some scratches in the bottom corner though pure cosmetics
- Asking $1100 and can get pics if required but you all know what they look like.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
