Item:
83 ADM AE86
bris northside
Website:
here
Item Condition:
gc
Reason for Selling:
need space
Price and Payment Conditions:
8000neg or swaps
Extra Info:
JDM 16v RWD 4AGE
Kaizen garage extractors
2.5" exhaust all thru with high flow cat
custom 8mm spark plug leads
SAAS pod filter
CA18 DET radiator
excedy clutch
JDM front brakes
UNknown front coilovers hieght adjustable approx 6kg springs
KYB G excel short stroke shocks in rear
AJPS 6kg springs
Cusco strut brace in front
AJPS strut brace in rear.
SAAS dished steering wheel and boss kit
Front Lip
Reverse vented fibreglass bonnet
TRD copy side skirts
Front flares
TRD copy ducktail wing
color matched bumpers
Trust gear knob
Swoosh water temp guage
Swoosh volt guage
pioneer head unit with aux in
pioneer 6" 3 way splits front
fusion 6"x9" 3 way splits rear
VL turbo fuel pump
Custom sunroof
SSR exc 15 x 7 black centers with polished lip
Pictures:
uploaded tonight
Contact Details:
0431374723
pm
here
https://www.sau.com.au/forums/topic/249322-ae86/
