Website: http://s160.photobucket.com/albums/t170/SVD115/SSS/
Item Condition: Good
Reason for selling: No longer needed
Price and price conditions: $3000 Negotiable no wheels, $3500 Non Negotiable with wheels
What you get:
rego untill the 5th of november
Silver 5Spd sss pulsar
with 15" Rays Gramlights with Re001 fronts and GIII's rear tyres. both around 80%
Koni Adjustable's with whiteline springs and whiteline front and rear sway bars,
Svd recaro Buckets
Svd Extractors and full 2.5' exhaust with a new end muffler only a month ago
JDM Front lip.
N14 SSS Steering wheel,
Solex Locks
removable roof racks,
Jaycar 6x9's rear on custom shelf, Blaupunkt 6" fronts, all sony wiring for a sub or two in the boot (power ground RCA's etc)
May come with clarion head unit depending on the price. double din surround and a single din surround as well.
Currently has a faded roof but its getting resprayed in the next week or so. was damage on the passenger side both doors have been replaced with silver doors off an earlier sss so the pinstripe is wrong,
it will come fully serviced, new plugs leads filters and fluids & brake pads.
has been my train station car since November im only selling it because i am buying a ute. handles like a dream, also comes with exa engine mounts so a ca18de will bolt straight in mate,
good little car not far from roady, as it had one in November! economical daily!!!
despite the photos having p's up this is not a p plate driven car. very rarely driven by my brother who is the p plater lol
Edited by mastadd
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
