up for grabs ,swop is my baby its a very very rare car atm there are only 8 for sale aust wide and where only 100built pritty much a
factory street legal racing car. unlike hsv ect it has koni suspention and racing gear high end stuff .reson for sale need a smaller car willing to trade swop
1999 vt si valanti series 2 corsa
masive 290kw sock car can hack up to 400kw esy more power than the vz r8 hsv
koni suspenion
17 rims good tyers
couler tungsten
custom csv body kit with custom car bra
custom stainless exsorst system comes out midel of car eg like bat mans car lol
leather and fabric seats
6 speed racing gear box same as race cars have
climet
cruse
lazer maped 5.7lv8 worked at factory
tint
log books
full eltrics
floor mats ect
just had $2000 full over hall
new oils coolnt.belts
plugs leads the works
.pritty much car is val at over $25000-30.000
due to masiv price dif car is not being sold with rego our rwc unless its car/cash trade
willing to swop for sumthing mech sound good km good mods looks good and safe car
for gf to drive to
can mms pics to mobs
im in melbourne vic more than happy to work deal out
going at majer loss just to big for what we need
(0421576411) note needs to be gone with in 3 weeks everything for rwc comes with the car tuns heads annywhere u got and qwicker than anny vy vz
and its stock factory car :)
best to mms offer to my mob our qwestions thanks
Edited by mordor22
sounds pretty unique mate! Any pics?
Please run spell check before posting anything again hehe. You even misspelt the model name- its spelt "VOLANTI" not "valanti"- this is the same in your carsales add :P
yerp no probs man on me mob so its bit bodgy .
it is and thats why i brought it now its to big for what we need
annywhere i go people look i have pics via mms only so if sumone sms me il send them .and if sumone could host them would be good
as .i only have the net on me shitty phone .
and i have pics of when car was firts built to from the guy at csv who built it :D how legit this car is sumone must wont kick ars beast
car is now on ebay with full specs and pics car will be sold 10 day swop auction . starts at 17.000 thats half what its worth best deal gets it
typ csv under cars on ebay
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
