hey all have got one of my toys up for sale I'm just not using it as i thought i would so its time to sell up
i got the bike and it was in need of a freshen up soooooo i rebuilt it
the engine is fresh with only genuine Yamaha parts used, the gearbox is fresh with only genuine Yamaha parts used
new piston, pin, rings
new timing chain,chain guide,tensioner
new bearings bottom end
new selector forks + 3rd and 4th gears
brand new twin air filter
brand new spark plug
brand new fork seals
all bearings have just been pulled down and greased
blue reikon taper bars
near new tires
frame guards
brand new gold x-ring chain
brand new gold sprocket
carbon fibre front sprocket guard
big gun race pipe and header (ceramic coated silver)
yamaha of troy sticker kit and seat cover
only using quality bel ray oils in this (still hasn't had the run in oil dropped from it yet )
bike is immaculate looks like it has just come off the factory floor and has never been raced not one cent to spend just jump on and enjoy i have done all the hard work for you the bike runs like a dream has full compression and starts first time will scare the shit outta ya digs trenches wherever it goes
i am not desperate to sell and will not budge far from this price
asking 5400 for it
owes me ALOT more and i have recipts for everything
PICS
http://www.skylinesaustralia.com/forums/04...0f-t266028.html
https://www.sau.com.au/forums/topic/266029-04-yamaha-yz-450f/
