hey, getting a tune next thursday and i need a 3" turbo back to cat, is this look alright? http://cgi.ebay.com.au/SKYLINE-R32-R33-GT-...%3A4%7C294%3A50 i dont want to sped all that much ive spent way more than i wanted to get it to the point of a tune. yes or no
https://www.sau.com.au/forums/topic/268003-ebay-exsaust/
Hi mate we got some in stock .we can sell you dump pipe $125.00 and down pipe for 125.00.or you can buy one piece type dump and down pipe together for $380.00 X-FORCE brand .you can come and have a look at 5-7 jade st maddington.
regards
raj
https://www.sau.com.au/forums/topic/268003-ebay-exsaust/#findComment-4568876
I wouldn't buy that stuff from ebay. Its generally china stuff. Which means its made to look cool, be cheap. But turns out that it might not fit properly. If you are lucky it will fit, but then warp, crack or corrode really badly. So it will become useless.
Best to buy stuff from Just Jap.
There is a JJR Stainless 3" Bellmouth Front/Dump Pipe - Nissan for 200$. Would be a better bet.
http://justjap.com/store/product.php?produ...=276&page=1
https://www.sau.com.au/forums/topic/268003-ebay-exsaust/#findComment-4569371
im confussed, you can buy a one peice? dump and down pipe and a two peice? i have no idea i just need a 3" turbo back to cat, is this the one http://justjap.com/store/product.php?produ...=276&page=1
https://www.sau.com.au/forums/topic/268003-ebay-exsaust/#findComment-4569452
Don't double post, or triple post. Wait for someone to reply. Otherwise u will get flamed.
U said u need a 3" turbo exhaust system. So you need a dump pipe, a front pipe, a cat, a mid pipe and a muffler.
Dump pipe comes in split or bellmouth (shaped like a bell - mouth) and a front pipe just blots up to that. Nissan make the dump and front pipe seperate, Which isn't necessary for you. SO you can run a front/dump pipe combo like I linked you.
Its your choice what you buy. Depending on price and what you want.
https://www.sau.com.au/forums/topic/268003-ebay-exsaust/#findComment-4569472
whitch one is better tho, the bellmouth or the one i linked, i dont mind paying more i just want something with alot of flow, ive alredy got a 3" cat back but tuner said get a turbo back 3" so im completing the system
https://www.sau.com.au/forums/topic/268003-ebay-exsaust/#findComment-4569482
It doesn't matter. Its presonal preference like I said. The difference in belmouth and split is minor if any at all.
SO JUST PICK ONE. They are both 100% better than a stock dump pipe setup. So get one. Whichever style u prefer
EDIT: I have a belmouth and would buy it again if I had the chance. The splitter in the split one can be a bit fiddly
Edited by reNEGaDe88
https://www.sau.com.au/forums/topic/268003-ebay-exsaust/#findComment-4569617
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
