  • Replies 290
If its on a weekend I might drag my ass over to it =D
LadyG - Banyo's not a bad area, was my turf for 18 years.. I grey up in Virginia just near the gold club between banyo-virginia stations
You guys could call it Club Noob (northside)
Yeah Banyo's alright... except for the smell from the canery thing.. and all the Indian men that walk around the streets at night.. They make me nervous going for jogs in the afternoon. But other than that it's good lol.
Im keen to meet up but Im shy! And I get nervous going to places where I dont know people lol. And I love ice cream so Baskins sounds good. I could only do a Friday though. Would be nice to nice to meet some chickys too :-)
You can meet me ^__^ Just looks for the crazy chicks in a 34 :) hehe!
Baskins is good, as long as they don't tell you to leave! lol
haha ok :-D
They wont tell me to leave after Ive eaten all their ice cream! hehehe.
And where exactly is this Baskin's? Street name etc.
Well I'll give you a wave and say hi :-) I'll be in my white 32. Im 5'11 so you cant miss me haha
John, do you mean the Nando's @ Beams Road intersection? That may be good, maybe we should do there?
That's the one.
Everyone seems to be keen on ice cream though, so looks like it's all gonna be about Baskins. I'll go to Nandos first. The rest of you can get f*cked :)
Also seems like everyone wants Friday instead of Wednesday.
Hmmmmmmmm.... If I knew for sure I'd have my car this week I'd say this Friday. Up to you guys. If you organise it, and I have the car, I'll come along.
Otherwise we can say next week to give everyone notice? Either way.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
