  • Replies 57
Posted Images
  • 4 weeks later...
...you're not welcome here anymore dude :3some:
Nah that looks alright hey...but put a spoiler back on...they look weird without anything on...even the stock one will do.
Street legal with no drama's ?
Ha ha, I still have the Ceffy till its sold.
The boot used to have a spoiler but the holes were only taped up so I got a carbon fibre lid for it and it make it look tough from the back....
Engine, gearbox, turbo and intercooler are engineered, but with a 3.5 straight through exhaust from the turbo back is way to loud so I'm looking at one of though varex xforce mufflers for it.
As for drama's, clutch failed after I bought it and drove from Brisbane to Sydney and the power steering pump decided to fail on me. But its all fixed now.
But other than that it make 401 hp on roughly 1.1 bar of boost and is a handful even with semi slick on the back.
Whats been happening with your Cefiro? How'd your HSD's go?
Going good man, got them but havent installed them yet, pending 5 stud conversion, brake and wheel fitment. Everything else is starting to move again, which is good. :3some:
Not sure on where and which brand to get my studs from.
the CF looks aight hey, CF roof and bonnet gets my vote.
What kind of 1/4 times does it pull, do you know yet?
Must be decent considering its weight and a 3.0 twin turbo engine pushing 400 out it's ass...must also be a bitch to drive in the wet too, haha.
Going good man, got them but havent installed them yet, pending 5 stud conversion, brake and wheel fitment. Everything else is starting to move again, which is good. :)
The car has run a 12.4 @ 122mph, with a lazy launch then wheel spin into third by the previous owner. I hope to get a flat 12 with launch control tuned into the computer, plus get some 1000cc injector and better coils as the are stock ATM and really holding back more power. Off boost its drives OK, in the wet I don't boost it, that's just asking for crash LOL...
  • 1 month later...
  • 4 months later...
Hey dude mean looking ceff, Its darrens old one isn't it? from autoshop
ALso did you get the S15 from peter? Hes the only dude i know crazy enough to do the conversion!
I bought it from a guy who imported it thru autoshop, dont know if it was ever his. S15 conversion was done by a guy named troy...
U mean brakes? and z32 calipers are a straight bolt on, just got some slotted rotor to suit.
oh yeah haha brakes... nah i mean with the bigger calipers having a slow/softened effect on the pedal, did you have to upgrade the master?
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
