hey guys my dreams got shattered today after trying to fit these onto my r33 gtst after just buying them at the start of this week. fell in love with the look and the rareness of these wheels! the rears were awesome and they stuck out of the guard just a tad just how i liked but the fronts did not fit due to no clearance for the caliper!!!!!!!!
i got these from jms in adelaide and they told me they came off a r33 skyline so i had no problems but they were obviously wrong and i'm not happy at all!!!! :)
i have to sell them now as i don't want to run spacers or anything. offset is unknown as it doesn't mention anything at all on the rim except for manaray, jwl and size. the rears though seem to be around the +30 mark and front within +38 to +30.
if you are interested bring your car around and we'll test fit the fronts on and if they fit they should be o.k. this is considering you dont have a 33 and have small front brakes. have a feeling they could fit on a soarer or fc pretty well. if you have a r32 i am pretty interested to see if they would fit on the front as they mentioned it would fit a skyline but they might have meant r32 and not r33.
*edit* the rears come with screw on/screw off spacers that actually bolt onto the wheel on the back of where the rim sits on the hub. its just under a cm.
specs are:
front 17x8.5 with crap 245/40R17
rear 17x9.5 with crap 245/45R17
the wheels are old but they are in good condition for the age. if you want show rims these arent it. they have a bit of gutter rash, some scratches but overall very good and still shiney condition. they have the centre caps and everything. give them a bit of a clean and they will look great like what they first looked like when jms got them in the picture. (picture is of the actual rims)
want $850ono and i don't want low ballers cause i love these rims. will swap for anything of interest. need these gone asap so i can get some new rims. pick up in western suburbs of vic or will send interstate but at ur own cost. call/msg me on 0432454387
Edited by jakez88
dude just keep them and run a 15-25mm bolt on spacer, too easy and safe, or even a 5-8mm slip on depending on how far off they are.... or as heaps of people do, file your calipers down a bit, you can take quite a fair bit
i think i might have to run spacers if no one wants to take them off me. gonna have to harden the fk up lol but i'll see how i go with the sale first.
mattysaidso the wheels are at japanese motorsport in adelaide or JMS. the wheels ur after are manaray vr5s but i don't htink they have em anymore.
i'm trying to source out a 20mm bolt on spacer for my fronts and new lug nuts as the standard nuts won't allow me to stick the socket in. clearance is to small. if someone wants them though and for the price i'm asking then i will sell them otherwise my adventure of getting these fitted on the front of my car starts now lol.
pms replied guys. no low ballers please. anyone interested?
i have put the bolt on spacers from the rear to the front and they still dont clear my 33 calipers BUT could most likely clear r32s as there is only a few mm needed to clear. any 32 owners taht are interested and wanting to test fit are welcome.
Edited by jakez88
alrighty these wont fit a r32 as i tried with a friends and didn't fit. need about a 15mm spacer or jsut go 25mm.
measured up as best i could the offset and they seem to be fronts +45 and rears about +38 so definately suitable for a soarer, supra or chaser etc that run high offsets. best to fit up before purchase though.
anyone have a soarer or supra? or if your a hard kunt and wanna run spacers on the front then buy them. $800 guys or throw me an offer.
Edited by jakez88
they wouldn't fit because of the calipers unless you use spacers up front
Edited by jakez88
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
