Hey everyone
i was looking into some clutches because mine has a bit off slip in it. I’m pretty sure its the clutch.. ill give you guys a quick scenario so then people can let me know defiantly if it sounds like the clutch is slipping.. For example if I’m at the light i have to take the clutch out a bit and then it doesn’t grip until the last moment and then grips…that’s the same as say I’m going around 60km/h in 3rd and then accelerate it doesn’t pull hard as it use to.
At the moment it has a heavy duty clutch but I’m not too sure what brand/model it is as it came with the car when i brought it.. at the moment I’ve got approx. 250 rwhp.. The question is what does every one think about the exedy 7056hdb (Heavy Duty Button Kit) clutch? i looked on the website and couldn’t find the rb20det engine under r32, so i rang up a local car shop and they gave me that part number..
I don’t mind if its heavy that’s cool, another question i had was would it put to much pressure on the stock rb20det gearbox?
Also another part that might be worth mentioning is that I do like to take it on the track once a month or so.
Besides that it’s just a Nissan skyline R32 gts-t with the rb20det and stated before has a stock manual box.
Thanks guys any help/input appreciated.. if any one is also using this clutch please feel free to let me know what you think off it.
Niran
https://www.sau.com.au/forums/topic/274460-exedy-7056hdb/
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
