Its time to sell my S15 due to buyin new house and am very sad so see it go.
This car is immaculate and has only had the best used on it!
Preferct JDM model, Never been pulled over by any cops.
2001 Japanese Domestic Market (JDM) 200sx S15 Spec R
-6 Speed Manual
-Approx 105,000km's
-Colour - Pewter
Price is negotiable $26000
Factory Options -
-Privacy Glass 5% Tinted Glass from Factory Nissan
-SUNROOF
-Sports Seats
-A Pillar Boost Guage
-Limited Edition Orange Gauge Cluster (rare)
-T28 Ball Bearing Turbo
-New Brake Pads
-Rear Wiper Blade (taken off ADM to lower costs)
-Digital Climate Control
-HID headlights
-Vanity Mirror in Passenger and Driver Sun Viso
-Door Tweeters
-Electric Folding Side Mirrors
Modifications -
-17" GTR R33 Wheels with Kumho Semi Slick Tires
-Vertex Side Skirts & Rear Bar
-Removed Rear Spoiler & Shaved Bootlid
-Silkroad Rma8 Coilover
-Silkroad Camber Arms & Toe Arms
-3" Stainless Steel Catback Exhaust with Custom JUNBL Flutes
-Nismo rear cradel options
-ORIGIN Clear Rear LED Tail Lights
-ORIGIN Twin Straight Front Pipe
-GREDDY Turbo Timer
-GREDDY Profect B II Boost Controller
-OS GIKEN Single Plate Clutch
-OS GIKEN Lightened Flywheel
-Front Mount Intercooler
-Walbro Fuel Pump
-Trust Airnix Filter Kit & Mushroom
-Front Strut Brace Painted Candy Apple Red
-Rocker Cover Painted Candy Apple Red
-Kenwood CD/MP3player
-Clarion 6" Front Speakers
-Fusion 6" Rear Speakers
-Trust Gear Knob
-Full Alarm with Kill Switch
-Muteki Racing Wheel Nut
There is so much more i have missed. The car was serviced by Nissan 2months ago and everything is running brilliant. New starter motor was fitted along with a bigger battery & all sparkplugs & liquids where changed too.
Testdrives welcome for serious buyers only.
Contact: Lewis 0432581798
