18" LENSO GF7's
Multi 4 stud. 18 x 7.5 +38
Come with tires, 2 good, 2 on wear bar.
Perfect condition wheels, no damage. still have sticky protective covers on the centre caps etc.
$1.2k ono or swap for other wheels
0416 427 472.
https://www.sau.com.au/forums/topic/279390-18in-lenso-gf7s/
