Fs: R33 Turbo, Fmic, Wastegate Flange, R33 Rear Coilovers, R33 Bmc, 38mm Wastegate, Pod Filter
Hi Guys,
Got some parts for sale that I don't need -
1. R33 Gtst turbo from S2 (better spool up) _ $300
Good condition
2. FMIC Micks Metal craft - $100
Old but gold, micks metal craft intercooler. Suffered a few injuries, but all repaired and working fine. Was taken off a running and working 210rwkw auto r32 (running fine, no leaks)
3. GAB super street rear R33 gtst coilovers, damper adj - $200
No visible oil leaks, reportedly good condition.
4. R33 gtst Brake Master Cylinder - $offers???? Good condition
5. Xspower external wastegate manifold spacer T3 to T3- $60
I got this so I could keep the stock manifold and go after market turbo, with external wastegate. Ended up going a/m manifold.
6. Tial Copy 38mm wastegate $100
7. Apexi Pod filter - $50
Good condition
pick up prefered but will post -
[email protected]
Cheers
Daniel
I also have a diff back exhaust, with oval Xforce muffler with removable silencer. Its stainless steel/polished - good condition. $50 firm.
  • 3 weeks later...
