i have few parts that i would like to sell as i have no need for them any more
apexi power fc hand controller to suit evo or rx7 in very good condition $170 neg.
greedy cooler pipe. the one that comes straight off the turbo and hooks up to your air filters etc.
came off a t78 trust turbo but im pretty sure will fit any big single turbo conversion. $270 neg.
just jap oil cooler core. $100 firm.
i am aceptting offers but please no low ballers. pictures as above. do apoligise for the quality of the photos phone was playing up.. contact number 0423682131 loky :) located in campbellfield, victoria.
