purchased these a few years ago but have done less than 1000kms on them.
they are for s13/cefiro etc
spring rates 10 front 8 rear
the camber tops were rubbish from new, purchased the bearing kit ISC sell last year, still wasnt happy with them so purchased brand new HSD camber tops which are direct bolt on's and are much better. theres $400 just there.
im asking $950 ono.
located in the westmead area of sydney.
PM or TXT 0450472446.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
