Aight fellas,
Long story short,
these are gifts from overseas that I dont need, so they are up for sale.
2x DAVIDOFF ULTRA (each contains 200 sticks)
I reckon they are not available here
$75 each or $140 both
Zara Sneaker with adjustable tops (you can fold it down or leave it high)
Let me know if you guys want to get it straight away, I can end the listing anytime.
http://cgi.ebay.com.au/BNWT-ZARA-SNEAKERS-...=item3caca793f2
Just leave a PM or sms me 0433552745 to pick them up.
Cheers,
Gerald.
https://www.sau.com.au/forums/topic/319053-davidoff-ciggies-and-zara-sneakers/
