// Hi there,
I am interested in the front and rear sway brace if they fit R33 S2, do you have any idea how much postage will be to Canberra?
Dave 0432234167
hey man the r33 s1 and s2 bodys are the same im 99% sure just lights engine differences and stuff like that i dont think postage would be over $60
  • Replies 77
$32 postage man
my bank details are brenton n neill
a/n 1015 6821
bsb 064210
so $232
you said tail lights were 100 not 200 bro so will send you 132 not 232. will be in your account by 2pm today. will PM my address.
yea sorry man
im keen is it in good condition
yea its good bro i got it about a year ago it was a reconditioned one and it probally did 15000 kms wile i had it in my car
  • 2 months later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
