Item: Pair of R33 lower control arms
Item Condition: Used
Reason for Selling: Have 2 2 many
Price and Payment Conditions: 150
Extra Info: The lock stops have been removed. There is also a crack in one of the ball joint boots, still fully functional.
Pictures:
Contact Details: Here or 0409706186
https://www.sau.com.au/forums/topic/332930-33-lcas/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
