I have finally have my GTR on the road again so have no need for my temp track car. I has been a joy to drive and put many other cars to shame. It has been resprayed in 2 Pac Nissan R34 GTR Bayside blue by Joe at Pro Finish Custom Painting, unfortunately I have scratched the rear bumper, bonnet, drivers guard and front bumper. Bad enough that it should be painted over. There are no dents in the pannels however just scratches. There is much good news about this car though. The motor was rebuild at NISSPEED 6months ago and has the following specs:
Full Blue print assembly
Balanced (pistons, rods, crank, flywheel and clucth, harmonic)
Forged Wiesco pistons (1.5mm over for more capacity)
Forged Eagle Rods ARP cap bolts
NDC bearings
New Lifters
Gold 2 pac rocker cover
ARP head studs
Adjustable cam gears
Steam pipe 4-1 exhaust manifold
Haltech F9 ECU
OEM Ignition (knock feedback and retard)
EVO 9 injectors
Walbrow 255 intank pump
Custom Modified OEM side facing Plenum- This setup with the intercooler provides a very short and direct inlet track for minimal lag and very crisp trootle response.
Water to Air Long Flow Intercooler with Alloy radiator and electronic pump also remote alloy water filler
R33 GTST Series 2 Turbo (ceramic turbine wheel, Carbon composite Compressor-very responsive)
Heavy Duty Organic Clucth (holds well and is kinder on the gearbox)
Gearbox from a 626(pretty sure internals are no stronger but ratio's are better for the track) filled with redline Shock proof oil.
ARD Approved Winged racing seats (ADR forms in the glove box)
Full 3" Exhaust with Magnaflow resi and Muffler(not to loud, just right)
Custom cold air induction and Pod Filter
Front Mount Oil cooler
Familia rear hatch with dual spoilers
Koni damper adj suspension
Adj camber kit
Polished Performance 5 Spoke rims(needs 4 new tyres)
Guages mounted above stereo in dash (boost, oil pressure, oil temp) also led illuminated switches for ACC and ON
Pivot Starter button(lights up blue)
Slotted and Dimpled gold pasivated front discs
Momo millenium style steering wheel (very small)
Power steering
Running and Tuned on E85(99c at litre from seaton united) also has a tune for BP98
Made 207kw and 420nm (at the wheels) before the plenum was modified. Dyno sheets will come with the car. I would expect her to have even more torque now. Cam gears have yet to be played with.
Absolutley Insane and light little machine. Handling in extremmely impressive. Car has been set for slight over steer and 4mm tow out at the front gives nice responsive steering...although on the street bump steer is slightly noticable.
She has been sitting for a coulpe of months and I would love to keep her but I need some cash to fund my other track car. It does need some love and tlc, however only cosmetic. The money, engineering and mods have been spent on all the right things to ensure this is a rewarding and reliable package for years to come.
It needs the following to bring her up to spec:
New set of semi slick tyres (kuhmo KU36)
Paint over scratches( Pro Finish Custom painting- Joe)
add some rego
Neaten up Haltech wiring
also recommend a roll cage
Collinsgrove Hill Climb, Old Motor
Completed the hillcimb as fast as an EVO 10. 3#sec zone. can't remember the exact time
323 At Mallala
Spents well over $10,000
asking around $5,000
Contact me on
0413023669
or SMS that you have sent a PM
Regards,
Matt
Will post up some pics when I get home.
  • 2 months later...
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers)
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
