Hi all im selling my highmount turbo setup hybrid t3/t4 comes with highmount manifold/ 38mm external wastegate brand new gate, turbo only 6000kms old dump pipe to suit also has 3 inch pipe to cat to suit rb20/25det looking for $500 ono willing to swap for r33 series 1 headlights also car made 230rwkw on 13psi on stock manual rb25det with stock mods pm or text me on 0428819885 located in melbourne eastern suburbs
https://www.sau.com.au/forums/topic/338261-vic-rb25det-highmount-turbo-setup/
Any other details on the turbo? Eg brand, shaft play, oil or water cooled and does it come with those lines. Interested pending response.
Cheers Jason
no shaft play perfect condition turbo doesnt have a brand on the turbo just says turbocharger t3/t4 500hp turbo plenty more power to go ust needs injectors and z32 afm n wind the boost up
didnt relise i put the wrong price up its atually $600 all parts perfect condtion stainless dump pipe with extension pipe to cat brand new 38mm wastegate and turbo is oil cooled no lines
oil line kits on erbay for bout $50-$60 for feed and drain
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
