Item Summary: wide flared s13 200+kws jdm as f#*k!!! WILL SWAP FOR ANYTHGING OF INTEREST jdm as f#*k!!!
Condition: Used
Reason for Selling: bord of s13s
Asking Price: 13500
Delivery Methods: PickUp
Contact Info: 0419139952
Extra Information:
hi all,
DECIDED TO BUILD MY DAILY FOR DRIFT SO IM OPEN TO SWAPS FOR ANYTHING THATS A COOL DAILY IE BMW,EURO,R324DR R34 ETC..
so basicly im bord of s13s this is my current one (and best iv had) i think my s13 count is up to 17ish so im well over it i thought keeping this one cool would keep me interested but here we are... looking for any swaps for anything of equal level thats A GOOD DAILY ETC (it must BE manual and obviously not a s13 silvia) other than that all welcome....
s13 silvia 1990 with s14 sr20det vct forged pistons rods rings etc.etc.
sard reg
fuel pump
480cc injectors(only thing that needs upgrading to get 250+kws)
z32
factry modded airbox with blitz pannel filter
3"exaust
fmic
gt2871r with .64 rear housing
prfec b II boost controler
alloy rad with new upper+lower hoses blitz cap
nistune computer
5speed manual
2way diff
sr brakes (shit abs removed)
5 bolt shafts
every adjustable suspension arm including control arms
hsd coilovers
bolt on flares nismo front bar side skirts rear pods(rare as f%#k)
genuine ssr limited edition formula mesh 16 by 9+3 front 16by 10+3 rear
cusco bolt in half cage(all rear trim still fitted)
window tint
s14 seats (very comfy and much better suport than standard)
usb cd player
r32 gtr steering wheel
yoda drift toy lol
im shore iv missed heaps and heaps, its a car best seen in person as photos dont do it justice as im shore some will know...
drew 0419139952
price ... $13.500 (obviously swaps prefered)
PICS CAN BE FOUND AT
http://www.nissansilvia.com/forums/index.p...howtopic=462857
Edited by sxg01d
hey mate iv got a white series 2 33 if ya keen for swaps its got - gcg high flow snail, plazmaman pro seris cooler. super spark coil packs, pod filter, greddy profec2 ebc, greddy turbo timer, bc br coil overs, work vs-xx 18x9 +15 front 18x10+25 rear and 116,000 km's just a thort any way man
want the stagea back? blak rims new tires coilovers gtr brakes cvs full service,wheel bearings. belt blah
if u want it i will get the whole thing painted at issabella
cant be f**ked paying to advertise it & i wanna go sideways again
NO THANKS I THINK I HAVE DECIDED TO KEEP IT THANKS ANYWAY(DAM CAPS LOCK)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
