Hi all,
My name is Tim, im from Maroubra Originally but living on the Central Coast atm.
Just bought a 1993 R33 GTS-T and have made my way to these forums.
Here is the first pic i have taken of her.
Been reading quite abit and i am loving the knowledge hit.
Hit me up on pm here if you live close by and want to go for a cruise sometime :)
Cheers
https://www.sau.com.au/forums/topic/342790-hi-hi/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
