Got some stuff here for sale that i dont need.
S15 Apexi PowerFC (PFC-SR2018) + New EL LED Hand Controller, (PowerFC Used, Hand Controller still new just took out of the box to check if it works with my pfc.) = $1000ono Posted Aust wide.
OEM S14/S15 VCT Solenoid Valve, Brand New in box = $150
Used Bride Seat Rail Driver side N049RX, Fits Ergo2, Brix 2 etc.. = $150ono
Set of BRAND NEW Genuine S15 Silvia Badges(Silvia, Lightning S, 2x Spec-R) = $120 ono
Pics Will Be Up Tomoro
Contact Via, PM Or SMS Tam on 0423506186
S15 Apexi PowerFC (PFC-SR2018) + New EL LED Hand Controller, (PowerFC Used, Hand Controller still new just took out of the box to check if it works with my pfc.) = $950ono Posted Aust wide.
WILL SEPARATE THE EL LED HAND CONTROLLER (WILL WORK WITH ANY PFC EXCEPT FOR TOYOTA JZX100 AT MODEL) Model No. 415-A030 Universal, STILL NEW WITH BOX. FOR $430 POSTED
UPDATED!!!!
S15 Apexi PowerFC (PFC-SR2018) + New EL LED Hand Controller, (PowerFC Used, Hand Controller still new just took out of the box to check if it works with my pfc.) = $1000ono NOW ONLY $850 POSTED AUSTWIDE.
OEM S14/S15 VCT Solenoid Valve, Brand New in box = $150 NOW ONLY $100 Posted
Used Bride Seat Rail Driver side N049RX, Fits Ergo2, Brix 2 etc.. = $150 NOW ONLY $100 + Delivery TAKE IT AWAY!! 100% Genuine.
Set of BRAND NEW Genuine S15 Silvia Badges(Silvia, Lightning S, 2x Spec-R) = SOLD!!!!!
Used S15 Stock T28 Rubber Intake Pipe = $10
S15 Airbox Snorkel Only = $20 (Few Scratches here n there)
Other Stuff:
Used Logitech X530 5.1 Surround Speakers = $50 (100% Good Working Condition 2 Speakers Got rips through the mesh outside the speaker doesnt affect anything)
ASRoCK X58 Extreme Motherboard = $150 (Almost New Condition Used for 1 month then upgraded to Asus Rampage Extreme 3) AsROCK X58 Extreme MB Comes With Box + All Accessories.
Pics uP Soon
Contact Via, PM, Email: [email protected] Or SMS Tam on 0423506186
  • 2 years later...
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
