Hey guys,
Im currently lookin for information about Geraldton(Car related), It's not an issue something i wanna discuss in public. So anyone here from Geraldton, can you please PM me as i have a few questions i need you to assist me in
i hope this is the right section. sorry if it's not!
thanks guys!
https://www.sau.com.au/forums/topic/356956-geraldton/
