Blitz SBC iD Electronic Boost Controller SPEC -R (dual solenoid) RRP $799
Click on the link below for more info:
http://www.blitz.com.au/SBCiD.html
http://www.scribd.co...-SBC-I-D-Manual
I've upgraded to an i-color so it's no longer required.
As you can see it's in very good condition, installation should only require some Vac hose & a T piece.
The Manual is included but in JAP so I've included the link above in English.
I also have a Blitz Power Meter RRP $300+ I'll add a photo ASAP
Total value is over $1000 I'm asking
$420 Boost Controller $120 Power Meter
The above prices are for Cash pickup only.
Add $15 for Registered Post
I will accept paypal but will charge 2.5% on top as that's what they charge me.
If you have any questions contact me here or email me at [email protected]
If you want to contact me by phone I prefer you call rather than sending sms as I just don't have time to reply.
Thanks for looking
Brett
Edited by Sydneyactionman
Hi there,
You're asking for $540 for both, I'd like to offer you $440 for both, let me know if you would consider this and I'll arrange for cash to be deposited asap.
I prefer local pick up, but you can also send to VIC 3012.
Thanks.
PS: Tried to PM you but it says you cannot receive PM's. Why is that?
$440 is way to low.
$520 posted registered is my final price.
Not sure why I can't get pm's I'll check my settings.
Hi there,
Thanks.
Check my feedback below to see I'm a trustworthy seller.
http://feedback.ebay.com.au/ws/eBayISAPI.dll?ViewFeedback2&userid=sydneyactionman&ftab=FeedbackAsSeller
I've also put the Power Meter on Ebay as I've had no takers here.
Ok $415 Posted Registered.
Check my feedback if you have any doubts.
  • 5 weeks later...
  • 5 months later...
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
