Hi all,
I'm looking to upgrade my current setup to a high mount GT3582r.
My current setup:
-Garrett GT3076r built by Bill at ATS (4500kms old)
-AVO I/G .73 a/r rear housing,
-.6 T04s front cover 3" intake,
-adjustable wastegate actuator,
-Speedflow fitting lines,
-3" bellmouth dump/front (came off c34 stag),
-3" silicon reducer to STD intake.
Setup makes 260rwkw @ 14psi on my r33.
Awesome turbo, massive midrange, minimal lag.
Price: $1600 + postage if required or swap for GT3582r setup
Located SA
PM, Call or SMS 0438 422461
Cheers, Kym
https://www.sau.com.au/forums/topic/367634-gt3076r-sa/
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
