It is with great regret that I have to sell our beloved Skyline...
1996 GTS-t series II manual
Nice clean car in white with stock standard body and interior, duco in good condition with no rust.
Has been 100% reliable and my wife's daily driver. Still gets 350km to a tank around town/ country, more on the highway! :-)
$000's spent since we bought this, lots of modifications done already but nothing that would attract the law or be cause for defects. (QLD).
96,000k on the odo, 7k since engine rebuild.
$15,000 ono. with 4 months rego, RWC
Located in Bundaberg, QLD
Mods (the good news)
Engine :
Rebuild 8 months/ 7k ago. Full details available.
$3,500 spent so timing belt, waterpump etc. all done.
Turbo:
Rebuilt approx 18 months ago, steel exhaust wheel.
Solenoid removed so runs up to std 7psi throughout rev range. (done by PO)
HKS turbo timer
Exhaust:
HKS Super Drager from turbo back. 3" with 5" polished stainless steel outlet.
Intake:
Large K&N pod filter (fitted 2 months ago, wished I done sooner as opened up the engine massively. Nice induction noise and noticeable but not obscene blow off valve noise).
Standard smic
Z32/ GTR? AFM (fitted by PO who obviously had plans...)
Suspension:
BC Racing RS series. Height and rebound/ damping adjustable. (6 months old)
Currently set to 345mm rear and 355 front (wheel centre to arch).
Did have this 20mm lower as seen in the in garage pics but too low for Bundy's speed bumps!
Wheels:
New rims and tyres (8 months ago)
19"x8" Enkei LF-11 in gloss black (8 months old).
Interior:
Clarion head unit, new 6.5" Pioneer in rear, new 6" Sony fronts (need fitted).
Looks as good as a 15 year old car would. All switches, windows etc. work.
Factory fitted sunroof, quiet, doesn't leak, buttons work.
Alarm:
New alarm, immobiliser, remote central locking. 2 remotes and keys. (8 months old)
Other:
New battery (8 months old)
Just serviced (5,000km service)
My TODO list (The bad news)
Head unit needs fitted properly, missing the factory brackets. It works but not great, first project.
Missing some lining in the boot covering battery, priced this up at $50-$70 2nd hand.
No glovebox, just a black perspex plate. (PO saving weight?). $60 2nd hand.
Rear parcel shelf could do with recarpeting, PO had 6x9's in.
Usual handbrake, gearshift boot a bit untidy.
There's nothing else apparently wrong with the car and I'm happy to let a mechanic/ RACQ look over it for serious buyers.
Nobody deserves nasty surprises and I'll happily discuss any genuine problems before haggling over the price.
Car is in Bundaberg but for a serious buyer, in a position to buy now and isn't going to offer silly money I'm willing to travel a reasonable distance for inspection.
Please respect my time by keeping questions to the sensible ones and negative comments to PM's only. :-)
Contact: Dave
m: 0458 797 736
e: [email protected]
or PM.
Edited by awhiteone
Some pics for now. I'll add more at the weekend after I've driven to a picturesque location when the light is right etc. :-)
Ride height at 335mm front, 325mm rear
Ride height at 355mm front, 345mm rear - current
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
