g'day fellas my bro is looking to sell his 32, mods are as follows.
engine:
s1 rb 25
splitfire coils
blitz injectors
z32 afm
tomei rising rate fpr
garrett 3037s, braided lines
turbosmart 48mm progate
6 boost exh mani
alloy rad
greddy cooler
oil cooler & relo kit, braided lines
fuel:
040 lift pump
044 external pump
alloy surge tank
driveline:
25 box
xtreme drift clutch
nismo 2 way 4.3 ratio
s14 rear cradle, solid offset bushes
solid diff bushes
suspension/handling:
33 brakes all round
project mu handbrake shoes
kazzama castor rods
custom shortened upper arms/nolathane bushes
cusco rear camber & toe arms
tien HA coilovers front & rear
front & rear strut braces
s14 lca's/boxed up
gtr rear swaybar
alloy steering bush
currently running stock 32 knuckles with s14 tie rods & ends
inside:
bride fixed back seat/ok condish. on genuine bride rail
deep dish s/wheel
boost guage
wheels:
front: work 17x9 +11 meshies with 90% ku36's
rear: work equip 18x9.5 +41 with shagged neutons
spares: 4x roh drift R's 18x8.5? + 38? all with 50% neutons
2x 17x8.5? + 28? equip's
2x 18x 8.5? + 30ish equip's, 1 cracked.
other:
3in dump/front pipe, screamer
3in straight through exh
bm44 brake master
ABS removed
wil also come with s14 steer rack with offset spacers which were used before when modded knucles were fitted until rhs one snapped, haha.
broken knucles and a pair of stock 32 one's can be included as well.
cars 70% stripped but will come with stock seats and most trim etc
prob a few bits and pieces missing.
this car has legit rego with this engine but is currently un-rego'd due to using it as a track car, but can be re rego'd if needed.
as for price, 14.5 k but am neg, not keen on swaps or parting it out.
ph 0423387100.
https://www.sau.com.au/forums/topic/373409-rb-25-r-32/
    • Let large companies that are making money off selling kits do the preliminary engineering for you. If they all do -10, then that is all you'll ever need.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
