i have a full 180sx sr20 full front black in colour $800
or will sell guards lights bonnet bar reo cheap
odd parts
all interior parts $5ea
carpet $20
centre consol $10
wiper motor $20
manual sunroof full kit $100
lh 180sx door black complete $80
digital climet controll rare $100
full interior loom $40
glove box $10
fuel flap black $10
180sx rear bar $20 with reo $40
tail lights and garnish $50
brake booster $50
clutch master cyl sr20 $30 with piping from slave cyl
clutch slave cyl sr20 $30 with piping from master cyl
1/4 glass lh and rh $40ea
handbrake $15
180sx radiator support $50
full seat belt kit 100% roadworthy $100
sr20 front lower lip standard $100
black 180sx side skirts unknown brand vgc $100
tailgate hatch $180
long rear with minor rh 1/4 damage for $300
cluster surround 180sx $20
180sx the metal plate that goes under the rear brake lights & over the bumper thingy black- $30
theres probably more just ask me
prices are neg to a degree and i will swap for things i need i.e. skyline 33 other 180sx or silvia s13 parts
call me on 0401043707 don't email me i never check it
pick up is in glenroy 3046 or can meet you somewhere can post small things
good luck and god bless
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
