Hey posting this for my brother even though its not a nissan
Hes got a 92 mitsubishi galant vr4 its a 4g63T model done approx 110 000kms all wheel drive model has all the unsual features that a modern car has like a/c, p/s cruise control very comfy seats n spotless interior for a car its age.
Its currently running a Td05 14b turbo with upgraded 510cc injectors also has fmic and walbro fuel pump thats all controlled by haltech E8 ecu even tho its only got 145 kw atw its got a shitload of torque so would b perfect sports car for ppl that have a family being a 4 door sedan with the set up to run more power with just a bigger turbo n maybe a h/d clutch
he looking for $11 000 ono
if any1 interested call or msge on 0405 816 829 or shoot me a pm here n i can email pics
Cheers :thumbsup:
https://www.sau.com.au/forums/topic/385151-92-galant-vr4/
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
