for sale is my series 1 jzx100
mod list
exceedy hyper single plate clutch with lightened fly wheel
cusco coil overs
series 2 tail lights
cusco strut braces
slotted rotors front stock rear rotors with endless brake pads all round
hdi front mount kit
hks super scilent exhaust with high flow front pipe
wheels are 19 inch avs model 7 powder coated white
apexi cold air intake brand new in box
blitz bov is plumb back atm but the adaptor is there to make it vent to atmo all brand new still have the box
car still retains the stock air box with hks pannel filter
i have polished the cam covers /throttle body /water out let/and intercooler outlet the j pipe and inlet manifold is done in black wrinkle coat centre cover is mat black went for a stealth look less cop hastle
the car has had full major service last week done water pump all idlers and tensioner /timing belt/spark plugs /coolant/all oils diff has motul gearbox has redline shock proof engine oil gets done every 6 months or 3000 kms car does not get driven much as i get a company car and the misses drives this to and from work.
spare parts that come with car are all left overs i have from a part out of another 100 i bought there is all 4 doors with most parts still in them there is a spare boot with wing all door class and rear windscreen /2 front seats /a spare series 2 dash with no lift /stock exhaust 3 spare 19 inch tyres spare rear bar that has gay fog lights in it series 1 tail light thats all i can think of atm
$17000 ono
phone 0409454739
https://www.sau.com.au/forums/topic/395527-jzx100/
Free bump for a very tidy, and nicely subtle car: makes me miss my Chaser! thumbsup.gif
What's the mileage?
Is it factory manual or converted?
If converted, does it have the Torsen LSD?
https://www.sau.com.au/forums/topic/395527-jzx100/#findComment-6284548
car has 90 k on it i converted it to manual before x mass has torsen lsd out of manual chaser everything to do with conversion is out of a manual jzx100 pedals box diff tail shaft i went to the extream of putting the manual tunnel in it and manual ecu car retains the original cluster just has the manual black face on it as that is the only difference between the manual and auto cluster everything kept original
if anyone wants to check it out i am more then happy to throw it on a hoist at work and you can have a look
Edited by bernardshorty
https://www.sau.com.au/forums/topic/395527-jzx100/#findComment-6284579
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
