Hey guys, first off im sincerly sorry if there is a specific WTB section but anyway.
I am chasing a Skyline as mentioned above in "project" condition so something that might need work done to it but not something that has gone to far with rust! I dont mind Rust aslong as its not to extensive or hidden by bog (the worst type). Would consider 240K or C210 as a rolling shell if the body is in good condition.
HR31 - coupe
DR30 - coupe (mabey sedan)
C210/11 - coupe or sedan
240K - coupe or sedan
Current offer is $2500 max but this is subjected to change and will be update accordingly, I do understand the rarity but then again im not looking for something in show room or original condition im just chasing a good, honest base for a project.
thanks!
Make/Model: hr31 gtsx
Year:1989
Kilometers:200,xxx on dash, 88,xxx on motor
Modifications:
alright do I got this car a few years back and was restoring it to its former glory.
I had to replace the engine and took me ages to source the original red top20 which had 88,xxx written on the covers. before installing the motor I replaced all 12 exhaust manifold studs and gasket with new genuine Nissan parts. Also fitted a s2 bb rb25 turbo and appropriate oil feed line along with a am performance sleeve style screamer dump and front pipe. Also has a31 side mount cooler.
Iv also fitted a Walbro ls1 fuel pump and custom 3 inch metal intake pipe.
Engine runs mint and sounds nuts!
Complete standard cat back exhaust fitted which needs to be extended about an inch to meet the dump pipe. $20 exhaust shop fix.
Will include I jun bl rear polished muffler and 3 meter length of 3 inch stainless tube to get a nice exhaust fabricated.
Fitted exedy hd clutch also when installing engine.
Currently has all standard suspension and brakes but with sale I'll include s13 sr20 front brakes and a full set of s13 coilovers, rears mint fronts are tein but need a rebuild.
Interior is all standard and all working electrics, weird jap features like air purifier on the back window and elec air cushion seats. Lol
Also has old school jap turbo timer installed which works perfecto.
Now I had every intention of finishing and enjoying this car but Iv started a new job working away and home only 1 week out of 2 months so have no time to finish it let alone enjoy it.
So the body work is 90% finished which has been done by 2 panel beater mates of mine.
It's had the boot lid spoiler removed (included in sale) and holes welded up, all badges removed and filled, all wheel arches lipped and slightly pumped.
It's at the stage it needs a skim coat over the guard lips then a wet rub and into a spray booth. It was goona cost me 1k to have it sprayed, maybe cheaper if you know a painter.
I also have a complete set of the original rear hot plate taillights included.
Currently rolling on silver 16x8 weld draglights, super light rims with brand new yokohama tread all round.
Probably best to text any questions or pic requests on 0423420713 as I work a lot.
Cheers much
Tom
Roadworthy Certificate:not required in sa
Accident History:nill
Asking Price:eoi?? $$4000ono
Contact Details:0423420713
Thanks but traveling to South Australia just to look and then go back again to bring it back is a tad to much for me sorry, sort of only chasing things within a 6hr distance of where i live (Roma, 6hrs from brissy). best of luck with it!
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
