They don't sound like CD's, pretty ordinary sound quality especially when you don't have an FM expander which limits what stations you can use
I found that one of those old school tape adapters that plugs into your 3.5m jack on whatever your device is gives practically the same sound quality as if you were using an AUX input. Will save you a bit of dosh as well as they cost less than the FM transmitter
ebay ones are rubbish. you pay 2 dollars, it sounds like 2 dollars. if you can afford to throw away 2 dollars and wait a whole month, buy one and torture your ears.
want a good one? pay $50, go a reputable brand. Aeropro, belkin...
tape adapters.... same deal. $2 is $2
aux input is the best direct way to do it and that will cost about $10 if youre handy with a soldering iron
Edited by Deep Dish V35
mitch if you are willing to spend that kind of money speak with Chris Rogers first. He installed a griffin Ipod dock in my center arm rest console years ago, works with ipod, iphone etc...and displays on the nav screen. Works a treat till today. I will show you on Sat. I believe he has slightly better options now including a streaming bluetooth option which is much better than FM transmited quality.
atm i have a crappy white one (dunno brand) that goes in cigarette lighter. It sometimes cuts a speaker out in the plug gets moved so if i turn a corner hard and my ipod moves around in the cup holder it will cut out. Also my drivers side door speaker has recently stopped working :(
Thanks for the feed back guys. Ended up getting a Parrot mki 9200 Bluetooth advanced hands free music kit. Has a LCD screen I've set up in the little compartment above the air conditioning. So it's hidden when o want it to be. It works bloody brilliant!!
  • 1 month later...
Hit up chris rogers. He is def the man u want to talk to. He hooked up mine easy transaction never had any issues. I actually thought it was just as good as a cd quality wisw. Hit him up mate you wont regret it.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
