pretty much brand new bosch 040, only had a max of 2 hours use
reason for selling - really didn't suit my application and issues with my fuel tank, easier for me to get a different style pump
$150 pick up or i can post at buyers expense
i live in Aspley and i work in Southbank so you can pick up from either one
text or call 0413377833 or send a PM
https://www.sau.com.au/forums/topic/408799-bosch-040-near-new/
  • 1 month later...
  • 2 months later...
